Cerberus
Cerberus the aardvark, not the hell-hound!!
- 11:24 AM
- Jan 20, 2020
- Florida (tampa area)
Initially I just wanted to stiffen-up my climb-saws especially the older units but in prior months I've learned a lot more about their construction and this 'problem' or possible-problem keeps coming to-mind: How on earth can the carb, and the engine, be on separate parts of the anti-vibe system?
IE, the carb is(almost always) right-under the rear of the handle, and part-of the "top, cushion-mounted" part of the saw (or spring-mounted, depending on brand) *But*, the carb-->engine block path....that relies on a precise, air-tight pathway...which seems to be achieved via using a rubber tube to mate the block//carb..
Have an itching to get out the scalpel, hard-rubber-matting, and epoxy and make 'wedges' to discretely eliminate all AV from my climb-saws, would love to hear how common it is that there's air-leaks / other issues due to AV mis-matches over time, hell I have a saw I got new ~1.5yrs ago and I can already see I'm "bending" the AV out-of-alignment, like my air/carb box and the rest of the powerhead are not perfectly in-line they are now at a cocked angle because of a while spent pushing-into that AV in 1 direction!
[also, in musing on this subject, I can't help but think that your control of the saw would go up, kinda like you 'feel' the wood you're cutting better because there's nothing "in-between" to dampen it, can totally see less bog-downs once AV is eliminated if one is prone to pushing/bogging-down their saw!]
