Correcting squish on McCulloch cylinders
farminkarman
I like the red & black ones
12:53 AM
Neenah Wisconsin
This is my first time doing this, so I figured I would try to document the process. After measuring the squish on this cylinder at 0.052”, I started by cutting 0.032” from the base. This looks the same as any other non-clamshell jug. B721B593-78CE-4BB6-8B18-6F8237277608.jpeg
heimannm
12:53 AM
Dike, Iowa
In my experience there is a noticable difference between the thin ring and thick ring versions of the PM610 saws, problem is the thin rings and pistons are getting hard to find.
I will also add that a healthy thin ring 600 Series saw is already at 200 PSI compression, that one may be even higher when you are done. Start looking for the aluminum starter pulley...
Mark
farminkarman
12:53 AM
Neenah Wisconsin
Mark
It will be interesting to see where this one ends up.
1:53 AM
Then I mounted the cylinder to my fixture after getting the fixture zeroed out. That is where I ran out of time. Next will be re-cutting the bearing pockets and the retaining ring groove.View attachment 375569
You guys and your big lathes….
Greg best get ready for the 039 insurgence
