Windsorman
Hi,
What's the best way to clean the case surfaces where the gaskets go? Those surfaces have oxidized a bit. Figured I'd clean them up carefully before assembling the saw. I've seen Matthew's method of using a die grinder with a scotchbrite wheel. Is that the best way? It seems a little aggressive but maybe it's the best way. I was thinking about running them across tempered glass with 1k paper. What about just using a green scotch brite pad freehand?
Thank you in advance for your advice,
Phil
Phil
