Cleaning gas tank
Hinerman
6:07 AM
NE OK
How do you clean/flush your gas tanks? Or don’t bother because there’s a filter?
67L36Driver
6:07 AM
U need a white plastic bucket.
Dump fuel in it. Slosh fresh in the saw and repeat.
Let the bucket sit until the trash settles out.
Decant into a separate jug for the lawnmower or the wife’s ride.
JimBear
6:07 AM
IA
Use some carb & choke cleaner if it stuck on otherwise just use the premix slosh method.
pbillyi69
4:07 AM
USA
if sloshing mix and dumping doesnt get out what is in there i check to see if its stuck down if so i dont worry about it. if its water or something i rince until clean
huskyhank
6:07 AM
TN
A little fuel and sloshing works fine on small equipment you can pick up, but if you work on bigger stuff get a Mityvac evacuator hand pump. Love mine. And it works on small stuff just fine.
Maintenance Chief
7:07 AM
South Carolina
Empty mix and flush with brake cleaner, blow out debris with air compressor.
