Change the ATF?
Nutball
9:54 AM
Mt. Juliet, TN
For you car experts... Should I change the transmission fluid in a 2010 Dodge Charger for the first time ever at 160k when it's acting up? I can't remember what my friend said, I think it was revving more or slipping some, or a delayed or hard shift. They noticed something different when shifting into drive, if I remember correctly.
My research turned up very mixed opinions and experiences regarding changing the fluid, and how much to change it. I was planning on replacing the filter and swapping the fluid 2-3 times to get most of the old stuff out, and resetting the TCM. I have warned my friend of the potential needing a new trans regardless.
Sloughfoot
7:54 AM
Norcal
Is it one of those you're told never needs changing?
Jusgunn3
7:54 AM
California
I think I would give you a similar answer unfortunately, I have read the same opinions. I would think you could change the filter in the trans and change the fluid without doing a complete flush. And then maybe again after a few hundred miles. Trans could be toasted like you mentioned. I changed mine in my ram at 100k and it has been fine for another 50k so far.
jacob j.
Only the weird
7:54 AM
Coastal Oregon
I think your plan is sound. I've been doing my Tacoma transmission about every 50k and that's worked well. The truck now has 330K and still runs and drives good. When I got my Volkswagen, I did the same since I didn't know the recent service history on the car - I changed the fluid and filter initially and then did two more fluid changes after 5k each.
Sloughfoot
7:54 AM
Norcal
I do a "refresh" on ours every 30k or so. There's no dipstick. Fill plug is a pita to get a wrench on and a fill line in. Basically drain the pan and put what came out back in but 10 times harder and more time consuming than what it sounds.
Nutball
9:54 AM
Mt. Juliet, TN
Yes. And there's no dipstick or drain plug. It's grounds for them to receive an F minus on their environmental score for making people neglect their car so they buy a new one more often. Where are the Big Oil subsidies for pushing frequent ATF changes on people?
Sloughfoot
7:54 AM
Norcal
Iirc first change I did on ours was 140k and it was a complete change. Still worked normally but was black as heck. Done a bunch of "refreshes" since and if I had it to do over again would have never bothered with the complete change.
Sloughfoot
7:54 AM
Norcal
That's ridiculous. May have but don't believe I've ever changed the filter on ours and it's pushing 300k, shifts like new.
EFSM
9:54 AM
Extreme southern IL
I bought a Camry at 250k with a terrible torque converter shudder that disappeared after flushing the original fluid with BG 312 ATF. I had it done after another 70k and it is currently at over 340k working great.
IffykidMn
9:54 AM
Minnesota
My Ram has no dip stick or oil drain plug in the pan just a fill tube, I use a vacuum pump to suck a quart or two out through the fill tube every year and add back whatever I pump out.
Sloughfoot
7:54 AM
Norcal
I'm convinced that's probably all that's necessary. I had a good transmission guy tell me he's seen them start slipping after getting a complete flush.
SawAddictedFarmer
9:54 AM
That's something you want to do about a quart every 200 miles or so, do too much at once and you can kill the transmission. I don't know why but I do know your chances are much better not doing a full flush. Your plan sounds good. Just don't drain/pull all the fluid at once.
Nutball
9:54 AM
Mt. Juliet, TN
It would be great if in such cases the old oil was put back in to see if it fixes the slipping or whatever other problems occurred.
Supposedly Lucas syrup (stop slip) additive can help some transmissions a lot. It's best just used to get you by as you save up for a fix.
ZERO
Simple Life
4:54 PM
Woods & Mountains
New fluid will no longer have fine particulates in it, partial slip held by the fine particulates may turn into a complete slip.
New fluid will dissolve all crud and carbon build up, overwhelm the filter and plug the fine valve body passages making her toast, irradic shifts, no shifts and such.
This is why there are so mamy negative reviews on neglected 100+k transmissions out there.
Personally slow approach, but warn your friend, is the friendship worth a toast transmission?
Look up total capacity and I would do about 20% to 25%, reset the adaptive TMC logic on a fully warmed up transmission, about 150F to 175F.
After reset plan a trip of about 20 to 30mi where we will see heavy and frequent gear changes. Do not drive on the freeway or highway at constant speed and constant gear engagement.
Then you want to drive a full PMC cycle, power train module will interact with the TMC to find a correct tune.
Irradic shifts and gear selections will be normal as the adaptive logic will learn new fluid characteristics and adjust accordingly.
Cycle lenght is hidden by each manufacturer, but about two full tanks or anywhere in the 600 to 1000mi should do.
Aftet repeat with another batch of change, reset TMC, and see if it improves.
Over the last 30 years I have had good luck with Lubegard Red.
All the best
