Ford3000
I put a chain on a new to me saw today, as I checked the tension it would be
slightly tighter at one point then loosen up slightly as I pulled it around with
the help of a screwdriver behind the cutters.
I have only had one previous saw that did this and I sold it because I feared
the shaft must of been out of true, and that this would be bad for the bearings
and ultimately lead to increased vibration stress and failure of the moving parts.
This was using a new bar and chain, I even used a second new chain to rule out
a chain issue.
Am I worrying about nothing here, my two EA4300 saws had no such runout,
and they were smooth in the hand to use, I have not started the new to me saw
yet as I may be returning it, so I have no way of experiencing what effect this
slight runout may have. The saw is fitted with a Sprocket and a Sprocket nosed
large radius bar, maybe the sprocket on the clutch drum is the culprit, I cant strip
this saw down as I am concerned about returning it in the same condition I got it
if I need to.
a chain issue.
if I need to.
