Are you sure it’s not the flywheel magnets you’re feeling? There’s only maybe 4-5 psi in the bottom before the transfers openWell there is a good bit of compression. Spinning the engine slowly by hand there is well defined resistance and then a pop/rush of air when the transfers open.
Mcculloch kart motors as well as others you could get aftermarket stuffers which fill the case more which takes away volume. You could also have custom full circle cranks that would take away volume but increase compression.
You touched on something here that a lot of people miss Lee. The amount of pumping action, or displacement, is the same regardless of case volume. Take away case volume, and case compression increases. Air stretches, and it compresses. So taking volume away will give it more movement up though the transfer passages because less time is wasted compressing mixture that will never leave the crankcase anyhow.
There are a lot of differences between reed valve and piston port motors and add a pipe into the mix and everything changes again! The mx 250 motors have changed a lot over the years, and usable power was always the goal, they could have built more power if they wanted too, the guys moding motors for shifter karts were always on the edge. Have heard a lot of modded 125’s making mid 40+ hp nearly matching a 250 stock.road race motors would also be more max efficient type builds, so the 125 is vary similar. I have played with case volume a fare amount and sometimes get mixed results, it doesn’t always work like the book says! Lol then you have reed spacers on the 250’s they clam it’s for low end power, saying adding volume adds low end powerThere is something more at work here. If there was not more to it every case would be as tight as possible. I guess every saw is different. My example is you may have a bore/stroke/timing/case combo that creates more pressure than one with smaller volume. Understandably less case on any same saw in theory should create more pressure. Pretty sure most motorcycle cranks get stuffed for more low-end response at the expense of top end, at least according to Eric Gore they do.
What’s the intake timing? Have you removed the coils? And is the muffler off both saws?I did a test with the 2 660's I have sitting here. One has a Hyway cylinder and one has a Huztl jug. The one with the higher transfers is popping harder. There must be more to it that just port timing.
Define “popping harder”. Runs better? Higher cutting rpm?I did a test with the 2 660's I have sitting here. One has a Hyway cylinder and one has a Huztl jug. The one with the higher transfers is popping harder. There must be more to it that just port timing.
The piston itself, and port volume, they are ChinaOn two of the same saw with the same case volume, what else would effect case pressure other than port timing?
