Broken plastic elbow on carb
Mark71gtx
10:02 PM
Fuquay Varina, NC
I was building an 026 the other night and when I fueled it up to test run it, it started to pee fuel everywhere. Turns out the plastic elbow that the fuel line hooks to was split. Is that a replaceable part, or the carb garbage? It is a Tillotson HU.
67L36Driver
9:02 PM
Browse your local OPE repair shop for a replacement cover for the pump side. Look in the box with junk carbs.
Tilly HU is common to a lot of stuff.
Chainsaw Jim
Con Artist LLC
7:02 PM
Springfield Oregon
There are little barbs available at hobby shops. The shops that supply building material for the little nitro methane or glow motors.
It isn't very hard to change them out.
Woods Works
9:02 PM
Home of the HODAG
I found them available as Tecumseh part number 640363. Common on the older ice auger engines with the smaller 2 hp. Also works for some walbro carbs.
backhoelover
SERVICE MANUAL MASTER
10:02 PM
lincolnton nc
if i remember correctly the tilly fitting is a little bigger on the brass where it presses into the carb
