BaronVonChickenPants
- 11:10 PM
- Sep 10, 2020
- Shoalhaven, Australia
Can anyone identify what this might be a clone of?
https://www.ebay.com.au/itm/283968247319
I have 1 each of the Giantz and BraumAg SX92 mkii, not the gen2 which is actually the mkiii. They are the same saw with the exception of the pull cord mechanisms, the Giantz has a clock spring you pull against that unleashes into the motor half way through the pull.
I have had the Braumr for a while and it has worked pretty hard slab milling iron bark and spotted gum with a 42" bar. It would be full depth cut at full noise for ~30 mins at a time before stopping to fill fuel and oil and go again. With 1 fuel stop it took 1 hour per cut on 6m long 1m wide spotted gum that had been dead a few years.
The math says they are closer to 87cc:
51mm dome top piston
43mm travel from bottom of muffler port to squish band.
I put the original 24" in a safe place, which is yet to be discovered. While shopping for a new 24" bar I found the identical looking Giantz saw for basically the same price as a bar and 2 chains. Take from that what you will.
When the Giantz arrived I pulled both saws down to compare and perform a bgd.
Compared to my Husky 281XP the carb, transfer ports and muffler port are enormous.
The carb mounts directly to the crankcase.
Muffler port is 41 x 16mm. Which seems pretty wide for a 51mm piston, even with a support in the middle.
There is a lot more scoring than I expected on the piston and cylinder for a saw with maybe 200 hours on it.
Open to suggestions on how to minimise the scoring and possible replacement cylinder and piston made with less chinesium.
