Yep, 48”. I do have 42” b/c but didn’t need the extra width. We did slightly trim the the largest log.Beautiful grain in them slabs. All of them. I didn't think I'd like the popular but after seeing the pics, it's not to shabby.
What size mill is that? Looks like 4 feet....
Did it smell kinda “sweet” and was it fairly soft to mill?Yep, 48”. I do have 42” b/c but didn’t need the extra width. We did slightly trim the the largest log.
He originally thought it was American chestnut, that’s why we milled it but someone thought otherwise so he used that app w/ a picture of a leaf and found it to be b-gum.
Very soft, like the poplar. Here’s his leaf pic.Did it smell kinda “sweet” and was it fairly soft to mill?
No pro here, but it kinda looks like black walnut.
Edit: The leaf is wrong for walnut, bark too. Pretty wood though
You NEED an auxillary oiler.I was blown away at how much the new loops stretched. At one point DL’s started skipping on the rim!
Lol, don’t need to call out that, I know it’s advantages. When I milled w/ the 50” I had oil out there. Typically after each cut, the saw gets revved high enough to spin the chain to get it full of oil. Only thing I call out is used motor oil and veg for lube. Wait.. no...You NEED an auxillary oiler.
Doesnt matter how wide the cut !!
Absolutely helps extend chain life
CALL ME OUT ON THIS !!!
I've milled a bunch, chains last longer with auxillary oil added at the end of the bar !!!!!!!!!!!!!
Doesnt matter what length bar, aux oiler helps because it oils the part of the chain that does the workLol, don’t need to call out that, I know it’s advantages. When I milled w/ the 50” I had oil out there. Typically after each cut, the saw gets revved high enough to spin the chain to get it full of oil. Only thing I call out is used motor oil and veg for lube. Wait.. no...
I’d also like a winch!
It was cheap and an easy install for my on my T slots. All my cuts take two people as I don’t have an automatic aux oiler and until the last 3 slabs didn’t have the wench. It really helps keep feed pressure constant. The stretch in the paracord was helpful.I’d also like a winch!
How far down on a log can it be used?
