Odd you guys bring this up today. I was thinking as the chain was getting killed by dirt... I need a short bar 404 set up for this crap with sand. Flushing yellow pine kills muh chain. It have plenty of 404 and buying more chisel full comp soon. My shortest bar currently running 404 is 83dl 28... too big.Oregon D009 mount hard nose bar , Oregon STA 200ATMD009 , Stihl 7T .404" sprocket - takes 65DL
The bar itself is 582mm/22,95" long
View attachment 238385 View attachment 238386
With loop and sprocket installed, the distance from the sprocket to the bars tip is 625mm/24,6"
View attachment 238387 View attachment 238388 View attachment 238389
I can confirm that this setup fits on my Dolmar's PS-6400/7300/7310/7900.
I would just buy one new. All my Stihl bars 28" and under are 050 but one 28" 063 404 Oregon one rivet. I have both ES 404 tips here just in case x2... two bars currently need tips. One of each.What about any 20” bar and just replace the tip?
Can you still buy a 10 or 12 from Stihl with an ES tip?It’s hard to find a .404 in a length shorter then 20” is what I’m getting at.
It would be easier to get a 18,16,or 10 in bar in 3/8 .063 and replace the tip to .404.
Did You figure out DL count for Your bar?
Looking for a driver length of this bar. I know is 20” long of .058 gauge. It has a .404 top so, I need a .404 length.
Go on eBay and find the gauge bar you want in 3/8 with RSN and throw the .404 nose on it. Cheaper and quicker than searching and having to pay full price for a specialty bar.Odd you guys bring this up today. I was thinking as the chain was getting killed by dirt... I need a short bar 404 set up for this crap with sand. Flushing yellow pine kills muh chain. It have plenty of 404 and buying more chisel full comp soon. My shortest bar currently running 404 is 83dl 28... too big.
Anyone recommend a good 16-20" 404 bar?... besides the hard nose here in Duro 16 050
I could rail grind it to 063 but...
Any Doo9 D025 or D024 will work for me. I have a file and stud bushings coming. Most of my bars are 050 in 12mm. I do have plenty of 10mm mounts also.
