I think @dall is the only one here crazy enough to do such a thing...
No, seriously, it depends on which bar you're running. A 32" bar generally has the same driver count between Stihl and Husqvarna, but there are minor differences between brands of bars.
28" bars usually require a longer chain on the Husqvarna chassis.
Sometimes you need to lengthen the slot in order to get them to fit a husky. And sometimes they are alright. Just depends on which bar length, bar manufacturer, and how stretched out the chain is
I guess the oil holes line up OK? That would be pretty important... I've had no luck drilling bars.
The oil holes are in almost exactly the same locationI guess the oil holes line up OK? That would be pretty important... I've had no luck drilling bars.
A good quality drill bit the size of the original slot, and a cut off wheel in a grinder is a pretty quick way for the home hack, myself included. But I’ve done it with a carbide burr alsoTried a 28" Stihl light bar. Slot is definitely too short.
A good quality drill bit the size of the original slot, and a cut off wheel in a grinder is a pretty quick way for the home hack, myself included. But I’ve done it was a carbide burr also
I don’t follow….Are you able to use Stihl specified drilling after? Or it still depends?
I don’t follow….
The Stihl bar will still work on a Stihl after you modify it to fit a husky
.Got a 395XP and would like to run Stihl bars. Looking at these bar adapter from Cannon.
With the adapter, do you still have to mill the bar, and/or have to add extra link to the chain for it to work?
Thanks for any info.
Sorry, for my typo. I meant after slotting bar, are you able to use chains with drive links written are the bar? No need to add an extra link.
I am ok with milling the Stihl bar as long as I can buy Stihl chains. I don't have the tools to add additional drive links. Please my dealer is solid so I really want to buy Oregon chains or whatever brands specifically made for huskies.
Oh, I need to clarify that the reason I'm going through all this hassle is because I only run light bars on 25in and up. I tried to source lw bars specifically made for Husqvarna but I'm having a hard time finding ones for the configuration I want. 32" 3/8, .063.
Ordered a Tsumara light bar from Amazon but got the wrong one, .050 instead of .063. It's about 5,6oz heavier than advertised. The .063 version will likely be heavier.
My dealer stocks Stihl lightweight bars and prices are pretty reasonable. $150 for 32in and 36in. $5 price difference.
What’s the pocket filled with?The new Husqvarna light bar.
https://www.hlsproparts.com/category-s/3960.htm
