- 3:42 AM
- Apr 24, 2019
- Waleska,Ga.
That’s very interesting. How do I find him on here? thank you!Mark H 3d prints the hand guard.
The 3002 stihl mount is 14mm , is it bigger than that?Shane I’ll check tonight. I think it’s the same mount as the 133, someone has filed the shoulders down to fit the Stihl 3002 mount.
I may have my mounts cornfused. They have filed the shoulders down to fit the Stihl bar that fits the 026. 3003?The 3002 stihl mount is 14mm , is it bigger than that?
Yep, that’s what they’ve done.Yes the 3003 is 12mm or basically the standard stihl bar for most of the line up.
I'm nearly certain they are. I replaced the studs on my KMS-4 with Jred studs so I could use a roller nose bar that I had.So are they the same studs as the 133 and such?
That is definitely a fine looking KMS-4You never know. Thanks for looking. I need two bar studs and the hand guard that mounts to the case just forward of the top handle.
It’s a cool little saw. Heavy as lead. Don’t know if it will run yet or not. View attachment 326894
Pretty rascal.
