I’ve been known to repair electronic boards before, made my own as well. Look at my YT channel or other posts I’ve made on this forum, not bragging here just have experience. I just finished repairing the board on my welder and posted it on this forum. You can download an app for surface mount components might tell you or help with the value of it, anyway it would be a starting point for you. Best way would be to see if the manufacturer will send you a schematic with the values of all the components on the board. If you can match the value you can order from Digi-Key. Many times I have seen electronic boards will use the same value cap in another circuit on the same board, this is not alway the case though. Sometimes there are numbers and letters printed on the component in question, if you can make out the printed info you can have a Digi-Key technician look it up and find the correct part for you. Well just a few tricks I have learned through the years, hope this helps.
