Another cracked bar pad repair.
srcarr52
8:46 AM
Iowa City
I was contacted from a member here about fixing the cracked bar pad of his 064 after he saw the last one I did. I don't know if he knew it was broke when he bought it... but it was sold to him this way.
Not a bad looking saw.
Now for the ugly.
And this isn't much of a surprise.
srcarr52
8:46 AM
Iowa City
After pulling the bar stud I noticed it looked like it had been welded on the end of it. I expected to see a welded on backer floating around in the oil tank but nothing... no sigh of what would have been a pretty ingenious repair. The JB weld didn't stick at all.
Typical red shmoo.
Someone was scared the flywheel would slip?
Ahhh, that's why... no key because it's a single keyway flywheel being used with the unlimited coil.
Deets066
AKA Deetsey
8:46 AM
Typical red shmoo.
That’s a mess
srcarr52
8:46 AM
Iowa City
As soon as you see the initials....
You know what the pics are going to look like, everytime it's the same.
The porting off the cylinder is very nice, clean lines, great chamfers and everything matches well side to side. The timing numbers are very similar to what I use... but the squish clearance was 0.047" with the goofy thick gasket and permatex shmoo covering both sides, wtf!
I'll get the cases cleaned up and welded maybe this week. The flywheel is taking at trip to Cuddle Lane to get the proper keyway broached in, and I'll use a the compressible steel gasket for the base which should get the squish to just a touch over 0.020". It will be a very strong running saw.
tickbitintn
7:46 AM
middle tn
The plating looks dark in some spots and other "streaks" look like it's been freshly scuffed with an angle grinder and 20 grit...
Is it smooth?
All his cylinders look that way in all the threads of past.
8:46 AM
Did you measure squish in all 4 corners? I bet it’s off big time.
These are something like .010 off the base and the band in the lathe after the belt sander attack. I had to go further, don’t have the exact amounts on me right now.
1BAE7B46-5FAB-49A1-8CD4-D5C831DEB381.jpeg EEA8EF68-05C2-4E35-981B-B67A099F21D3.jpeg
srcarr52
8:46 AM
Iowa City
View attachment 247167 View attachment 247168
I measured from the base to the squish band in 4 spots, all within 0.001". This one was a lucky one.
RI Chevy
8:46 AM
earth
Must have been one that he had someone else do the machining on...
Pafolo
OPE Member
7:46 AM
USA
Who's this JMS hack job?
mgr1
2:46 PM
Belgium
Jim. There are a "few" post about him.
