Air filter lower part 088 in 084
RomuloTDI
Active OPE Member
6:14 PM
Spain
Good night again from Spain,
I wanted to ask you another question: here in Spain it is very difficult to find the original filter for my Stihl 084 chainsaw (this model: https://www.gardenparts.es/es-es/filtro-de-aire-para-stihl-084. HTML)
So he thought that perhaps the change could be made to mount the oval filter (This: https://www.trbl.es/es/0030904-filtro-de-aire-adaptable-stihl-044-046-048-064 - 066-084) so searching for information I have seen that the Stihl 088 has a lower filter very similar to that of the 084, and apparently it is valid and fits, but could someone confirm if it would fit?
The idea of mounting this lower filter on my 084: https://shop.saegenspezi.de/Air-filter-lower-part-base-fits-Stihl-088-MS-880-MS880 and the necessary piece to be able to hold the top cover which is this: https://shop.saegenspezi.de/flange-for-baffle-fits-Stihl-088-MS880
Have any of you installed these parts on your 084 and can you tell me if they fit and the modification is correct or on the contrary, would the parts not fit?
RomuloTDI
Active OPE Member
6:14 PM
Spain
That is the filter kit that I have right now on my machine, and I want to mount the other one that I point out in the post, which is this one: https://shop.saegenspezi.de/air-filter-fits -Stihl-088-MS880- MS-880 and to assemble it I need the base (this one: https://shop.saegenspezi.de/Air-filter-lower-part-base-fits-Stihl-088-MS- 880-MS880 and the piece that holds the cover top (this: https://shop.saegenspezi.de/flange-for-baffle-fits-Stihl-088-MS880) but I wanted to know if these two pieces of the Stihl 088 fit on the Stihl 084
