tree monkey
- 12:34 PM
- Dec 14, 2015
- wi
Any chance you could tell me the over all length and pin to pin center length on your 661 rod? Yours might be topless right now. Thanks.
I have a 661 pulled apart out in the garage awaiting new bearings. Message me tomorrow or Monday and I can get you close on those numbersAny chance you could tell me the over all length and pin to pin center length on your 661 rod? Yours might be topless right now. Thanks.
@tree monkey
Would you think it wise when a fella is working on one of these type saws to remove the two fasteners on the deflector and put some loctite on them and re-install?
Can you measure the crank for our mate up above cuz?Very interesting video Scott! I have a very high hour MS661C in bits on the bench at the moment, it was badly siezed and these were the mains. Clutch side cage is two thirds gone.
I can prolly try in the morningCan you measure the crank for our mate up above cuz?
From my rudimentary measurements with calipers you are 64mm pin to pin and just on 91mm overall rod length.Any chance you could tell me the over all length and pin to pin center length on your 661 rod? Yours might be topless right now. Thanks.
You sir are a gentleman. Thank you. Close is good enough. I'm working on if an idea is feasable. Thanks again for your time.
