- 1:50 AM
- Jan 8, 2016
- Farmington, CT
Another substitution! OEM #503668404
After buying a brandy new 395 crankcase, I noticed the tank vent tube is not included.
Of note, it is special order, and about $8 .... this is stupid. Its poly tubing, with a coil spring pin, thats it. Its not special. and not worth 100x markup.
SO.....
Mcmaster part # 5958K12 for tubing
and
91598A250 for the coil spring pins ....
BUT!!!!! HELP!!!!! the coil spring pins I got are 1/8" diamter OD... the one from husky is 9/64" OD. I cannot seem to source 9/64" spring pins!!! they are 3/8" long or so ... 3.5mm or 9/64" would work best
1/8" does actually work, but it would be nice to get as close to ideal as possible.
SO.....
and
