WANTED 385xp flywheel side case half
mnmforestry
3:35 AM
WNC
i messed up my case half and need the clutch side case half. Preferably no stripped holes and in decent shape. Thanks
mdavlee
Hillbilly grinder
3:35 AM
TN
What happened to it?
mnmforestry
3:35 AM
WNC
Long story. Couldn't get clutch off and used impact with rod through connecting rod and it chipped a deep groove in the cylinder mounting surface. Sucks
mdavlee
Hillbilly grinder
3:35 AM
TN
Ahh. I have one that's been jb welded around where the drum goes. I just been using to mock cylinders up on.
mnmforestry
3:35 AM
WNC
Yeah. Would rather have one that's ready to go.
mdavlee
Hillbilly grinder
3:35 AM
TN
It was on a working saw. I just pulled the top end and put on another case since the coil came loose and stripped those holes. There was a new set of bare cases on eBay for under $200.
mnmforestry
3:35 AM
WNC
That would be a good deal right there. I'll check it out thanks.
mdavlee
Hillbilly grinder
3:35 AM
TN
Either of those has the $35 bearing and seal combo in it already.
TUBBER 340
12:35 AM
Nanaimo BC
I've got lots of 385/390 cases
Sent from my SM-G920W8 using Tapatalk
mnmforestry
3:35 AM
WNC
Is that for both sides. If so I'll take them. Are all the holes still threaded and none of the corners broken. Just checking my bases and making sure that it's usable. Doesn't have to be pretty just all intact. Thanks
TUBBER 340
12:35 AM
Nanaimo BC
Ya that's for complete set I've got alot of 385 cases I'll pick the best set that will be usable with no chips stripped holes etc
