FOUND IT 357/359 fuel tank
Trader history (2)
oddsaws
1:08 AM
Bartlett TN
Looking for a good condition 357xp/359 fuel tank handle. Shipping would be to zip 38002.
Message me if you have anything. Thanks!
Member
1:08 AM
It was a bit grody, so I gave it a trip in the parts washer so it could be inspected decently. Doesn't look too badly once cleaned up, however there was a small chain dismount mark right behind where the handle mounts on the bottom, I think you can see it in the picture of the bottom. So, I pressure tested it and with some soapy water confirmed it did not leak, it did however leak a bit from the tank vent, you can see it foaming in the pic of it with the tester hooked to it. So, the tank vent will most likely need to be changed other than that while not pristine perfect it should be fine on a working saw.
If this is amicable to you send me your address in a DM, PM or whatever they're calling 'em these days and I will send it to you.
Note: this was from what was left from a parts saw here from another member, earmarked to help other folks saws and am honoring that wish. There's not much left a handle, muffler and a brake flag if anyone needs them holler at me.
