Adjust it to the specs in the manual. Do you have an rpm meter? I think idle is around 2700 for the 346.
Start with the L screw all the way in and turn anti-clockwise one full turn. Start the saw and turn the L screw each way slightly until you find the sweet spot. Then adjust idle screw.
