SELLING 3/8 semi chisel .058 100ft roll x4
Trader history (2)
Stevetheboatguy
3:31 PM
Nw IL
Have never sold any chain. But I have four 100ft rolls of this .058 semi chisel low kick back. Not the chain of preference but how does $175 a roll and actual shipping sound? Make me a offer if I'm outta line or if yer just a cheap bastered :thumbup:
I believe they are full and have all the presets but will double check before they ship out.
Steven
Edit: I'd also be able to make loops if anyone needs a few. Just let me know what dl and how many.
vienster
OPE Member
4:31 PM
VT
Is that considered a bumper link? If so, is it really that bad? Are all low kickback chains made with bumper links or is that something else? I almost bought 100' roll of bumper link carlton recently for 177 shipped, but i'd have had to switch bars.
If I didn't like it I would've just sold it or made chains then sold them on ebay.
Stevetheboatguy
3:31 PM
Nw IL
I honestly have not a clue. @Philbert is the chain expert around here.
I've run a few loops of this and it's actually not bad at all. Might not be the best for doing plung cuts. But it cuts way better than I was expecting it to.
Steven
Philbert
Chainsaw Enthusiast
3:31 PM
East Dakota
*The photo above appears to be a bumper drive link chain, like the first photo below. The low-kickback bumper is part of the drive link. There are several variations, but in general, the bumper aligns with the depth gauge and 'presents itself' when the chain moves around the nose of the guide bar.
Most users find that this cuts fine, when properly sharpened, although, it might be slightly slower in bore cutting. I have seen experienced operators win informal races with this type of chain.
*note that the EXCEL chain pictured also has dual depth gauges, which is not common, but not unheard of: it has been used on some other chains through the years.
This photo is a bumper tie-strap chain. The low-kickback bumper is part of the tie strap. This was one of the first low-kickback designs, and the type that some people make fun of as 'safety chain'. It will still cut your leg off.
Again, this chain cuts fine, when properly sharpened, although, it might be slightly slower in general cutting as well as bore cutting. Because the bumpers fill in the 'gaps' between the cutters, it is not as good at clearing chips, which can be an issue on larger logs (greater than 24"?). But it provides a smoother cut on smaller limbs and branches, which makes it a nice choice for limbing and pole saws.
Most low kickback chains fall into one of the general categories above. There is the exception of the Oregon 'Vanguard' chain with its unique depth gauge (photo below).
Bottom lines:
- All of these chains will cut well in general use if properly sharpened.
- Some guys blame their poor understanding of, or skill at, sharpening on 'safety chains'.
- Regardless of appearance, the chain has to pass a performance test to be labeled as 'low-kickback' or 'reduced kickback' chain.
Philbert
vienster
OPE Member
4:31 PM
VT
That's some solid info. I swear by the timberline sharpener and will never use anything else again. I cut six cords of wood with one chain after I sharpened it with that sharpener. I'm probably wrong, but I thought it was better than when it was new on some of the sharpenings, but I could've been changing the sharpening angle without knowing when I first got it.
I guess I should've jumped on that bumper link chain for that price. No wonder the person bought both 100' rolls.
9:31 PM
I have obtained dozens of loops of low-kickback chain for free, because some guys turn their noses up at it. Cuts fine for most uses.
Philbert
I got several Vanguard loops from members on here.
I like those chains, great steel - I just "take care" of the Vanguard feature.
9:31 PM
Steven
View attachment 265093 View attachment 265094 View attachment 265095
I'd use it, although I prefer full chisel Oregon.
Pitch, gauge and sequence are what I use mostly, I may have to contact You for a loop or three to give a try.
