- 7:14 PM
- Jan 8, 2016
- Farmington, CT
288 and 394 goodies and screws and other stuff.
300 bux shipped lower 48 paypal ff.
One of the 288 oilers is pitted too heavily to use. But likely good for parts. The other appears usable once cleaned up.
Updated parts photo as of 4 10 20
Lots of stuff here. Oem piston pin bearings ....394 choke levers which are nla. New 394 intake bolts and 2x of those 60mm anterior case bolts. The low top 394 horn is missing the metal inserts but has the rubber o ring which is nla. Some oem pawls and circlips. Head bolts. 288 muffler bolts. 288 tensioner. Some random fuel / oil caps.
Am 288 air shroud ... am 394 muff supports. Some of this is am but mostly oem. Will separate but would rather keep lot together.
