FOUND IT 2166/372 Muffler
Trader history (1)
PA Dan
7:14 PM
White Oak PA
Need a muffler for a 2166 build. Not sure what saws came with the same muffler but you Husky guys will. Let me know what you got!
7:14 PM
All 365/372 oe xpw xt are the same
Ditto on jonsereds versions 2165/2172 etc.
7:14 PM
This is one rare situation where I prefer the AM part to the oem one. Cheaper too. The nwp and hyway seem to be made of thicker metal than oem. Less likely to crack/dent. They hold up well. Ditch the crappy screen that comes with the muffler though, they have disintegrated on me after some run time. The paint on the hyway muffler sucks and rusts quickly. Repaint with hi temp grill paint and fixed. Also the muffler gasket that comes with these mufflers I prefer over oem, it’s thicker.
chipper1
7:14 PM
Grand Rapids Mi
When swapping the muffler on my ported 2166 the one I was putting on needed the bracket that came with it. I tried the one from the 2166 and there was a gap between the bracket and tye chassis. I was under the impression it was a 372 muffler, but I'm not 100%.
@mdavlee this was on the one I got from you, anything to add, was it for sure off a 372.
Also want to ad that the mounting plate on the 2166 muffler was thinner than the one I replaced it with.
Dan I think I have a new stock jred muffler here with the bracket, want me to put it in the box.
PA Dan
7:14 PM
White Oak PA
Hey sure Brett if that deal goes through!
7:14 PM
Did you have the bracket on backwards?
Johnmn
6:14 PM
Minnesota
Dan I have one it has 3 small holes drilled in the front. Otherwise not too bad.
7:14 PM
Same here i have about a dozen 3.00 china mufflers
I tried a variety of mods too
Still holding up great.
Better built than the 268/272 version
https://cdn.shopify.com/s/files/1/0...t_DMUF372_Muffler_372_grande.jpg?v=1540912698
Check out this beauty 95.00
chipper1
7:14 PM
Grand Rapids Mi
There's always a chance lol.
@Armbru84 was supervising so I'll blame him :biggrin:.
I was wondering if it was off a 390? The muffler had to be used with the bracket that came with it.
That is a buet :eek:.
A nice hole through the mount works well along with opening up the stock opening and a screen can be added(and should be on the front).
PA Dan
7:14 PM
White Oak PA
@Armbru84 was supervising so I'll blame him [emoji3].
Never put the blame on someone that size![emoji1787]
David Young
Safety First !!!!!!
7:14 PM
vt
mdavlee
Hillbilly grinder
7:14 PM
TN
I’m pretty sure it was a 372 one. Was it aftermarket or oem? Seems several of them the bracket has to be tightened down and bent to be touching.
chipper1
7:14 PM
Grand Rapids Mi
Not 100%(I'll look later), but I remember the flange looked way better on it and thinking that was an area they must have skimped on the jreds. It was out at least an 1/8, but I think ,more than that, as Dave said maybe I had it on backwards lol.
mdavlee
Hillbilly grinder
7:14 PM
TN
The 390 and some aftermarket are thicker flanges and stick out further when it’s put in a 372 series.
