WANTED 181/281/288 parts.
heartwoodlover1001
7:53 PM
Beautiful Michigan
If anyone can help lemme know.
Need carb. assembly bolts
Muffler possibly?
Ignition wires
New clutch drum with a non 404 if possible
Piston
Any/all grommet/rubber in good/great shape.
Possible clutch cover.
If anyone has any of this please send message.
cus_deluxe
terms of service violator
7:53 PM
Michigan
fwiw, i bought AM hard rubber AV's all around for mine for about 1/3 the price of oem and have held up so far (under very limited use haha). may have a clutch drum but no help on the rest sorry.
Jon1212
Birch! Please.....
5:53 PM
Utah, unfortunately.....
Muffler possibly?
Ignition wires
Piston
Check HL Supply at the top of the main page. They have AM mufflers on sale for $15.99, AV bushings for $3.99, Oregon clutch drum (3/8 7 tooth) for $22.49, etc.
@T.Roller may also have some of the parts you are looking for.
T.Roller
7:53 PM
Southeast, TN
Actually I'm slowly building enough parts to build another one myself.
Here for the Yum Yum Sauce
6:53 PM
Not sure which model you are actually working with here.
Aftermarket pistons work quite well in used OEM cylinders - Meteor piston from HL http://www.hlsproparts.com/Meteor-Husqvarna-288-piston-and-rings-assembly-p/pc1735.htm
For the grommets, bellows and ignition wire as well as carb bolts Husqvarna is the only place - http://www.husqvarnapartsdistributors.com/p/Husqvarna-parts
Clutch cover with brake - http://www.arbortec.net/product-p/pj28803.htm
An After Market carburetor is good, especially if you replace the metering lever spring with an original, this can be bought from Husqvarna as well.
HL Supply has Oregon clutch drums these are good, the AV's are good there as well,
About the only thing I have here is a carburetor and it is at a parts only level, been going through my stash pretty good lately. But there is not one thing off that list that can't be had from Husqvarna or AM. Good Hunting.
heartwoodlover1001
7:53 PM
Beautiful Michigan
Awesome i will look at those places. With the carb i am trying to locate the bolts that install the whole unit to the cylinder.
6:53 PM
Should be able to get them from Husqvarna as well as most things for a 288. Sometimes when updating certain things to the more modern/latest version, the whole business needs changed over. Like an oil pump and worm gear for example. New gear wont fit in a old pump and it goes on like that.
I did look at the carburetors I have here and they are staying right here for parts(they are pretty bad). :(
heartwoodlover1001
7:53 PM
Beautiful Michigan
cool cool understand stump shot. if anyone has any access to the bolts which attach the carb to the cylinder let me know.
T.Roller
7:53 PM
Southeast, TN
Find out what size and length they are, go to your nearest hardware store and pick some up. Or do like I do and carry in a box of parts and start digging thru their hardware
chainsawman2011
7:53 PM
Michigan
I have some 288 parts. Were u at in Michigan. I live in southeast Michigan about 20 minutes from port Huron
decableguy2000
7:53 PM
WNC
I have a couple of ugly mufflers, new tank vent, fuel line groumont, starter housing,
