HUSQVARNA 141 Compression
jasper89
9:03 PM
LaCrosse
A neighbor has a clean Husky 141 that will start with mix poured in the carb but then dies. In looking at it the compression is about 130. Is that too low for this saw? Probably need to replace fuel, impulse, air. Any other suggestions? Plan to check vac and pressure once we are further into it.
Thanks for any input.
lumberjackchef
9:03 PM
Southeast Kansas
Have you pulled the muffler and checked the piston. I have had several of these trick me into thinking they had good enough compression to run and found that they were already slightly scored on the exhaust side of the piston....
Sent from my moto e5 play using Tapatalk
9050lx
10:03 PM
FL
Very late reply, heh heh.split impulse line likely.Hopes this helps someone.
