weeks auto
- 11:16 PM
- Aug 22, 2017
- Stuart, Iowa
A while back I got a freebie smashed 066 that I that was barely good for a parts saw. After pondering what to do with it and asking some questions on here I decided to build a play/novice race saw with it since it would never be a show piece, and since I bought a much nicer 660. So over the last few months I have been watching the sales on HLS and have picked up the needed bits for real cheap to make it a runner again.
I hope to get it running with just a muffler mod, .020" of key timing advance/ and .010 paper base gasket to bring squish to .022. After it runs decent I want to try my hand at porting it ( or destroying it), as I have finally acquired enough cheap amazon porting tools. It should be a learning experience either way. Any critiques, advice or criticism is welcomed.
Today it was raining so I decided to jump in and see if I could assemble this roach and get it running. I got it all together with .022 squish, advanced the timing by taking .020 off the key. When I was installing the intake I notice a small slit in the rubber so I did not get to fire it up. Now I have to wait for an intake which who knows how long that will take from my local dealer.
As for parts, I am using:
Stihl OEM-
Piston and Cylinder, with fin damage
Carb and intake
Bearings
Impulse and fuel line
Air filter cover (plastic welded)
066 Badge
recoil
oil pump
Brake flag and parts
coil
Flywheel Missing 4 fins
Clutch and related parts
AV Rubbers
029 Plastic clutch cover
Chain adjuster of a parts 036
AM Parts-
Case
Complete handle/tank
Wrap handle
Muffler
Top cover
HD2
Seals (probably a mistake)
What I started with
Where I am at today
Stihl OEM-
Carb and intake
Bearings
066 Badge
recoil
oil pump
coil
AV Rubbers
AM Parts-
Case
Wrap handle
Muffler
Top cover
HD2
What I started with
Where I am at today
