back of beyond
Active OPE Member
All:
My favorite saw has an annoying problem. Runs like a raped Ape till About 1/2 tank in, saw starts to sound like its starving for fuel, acts exactly like a saw does when you run out of gas, air leak suspected but cannot locate.
This is a flat top, non de-comp saw. It does have a timesert in the spark plug hole. Aluminum flywheel, 1311 coil.
Saw has 165 PSI compression. It holds a vacuum for 10 minutes at 80kpa. ( I do not have a pressure gauge)
The carb was replaced with new Stihl/Walbro carb. Coil has been swapped with known good coil. New seals, intake, impulse. New tank vent, fuel line and filter, OEM parts. Cylinder is OEM and piston is OEM.
Any suggestions before I get mad enough to sell this for parts? (hate to do it!)
