blackjack99574
- 5:15 PM
- Jan 9, 2016
- Cordova, Alaska
Got an 064 with oem cylinder. Piston appears to be OEM as well though ive no way to confirm it. Compression was taken at 6500ft above sea level. While actual compression remains the same, static compression as displayed on a gauge changes with elevation. We lose approximately 3% for every 1,000 feet we go up, which means that we've lost 19.5% at 6500 feet above sea level. Doing the proper math, 131 PSI times 1.195 gives us 156 .54 PSI at sea level. Got a new pull rope, rope handle, fuel hose, impulse line, sprocket, washer, e clip, spark plug. Will come with am sprocket cover and a set of dogs. Vacuum and pressure tested fine. Asking 500 plus shipping from new mexico.
