Cracker Boy
Fl cracker
- 2:38 PM
- May 31, 2016
- Florida
Stihl 036 with pro topend with decompression release.got saw from same member as the pro 036 i listed.had a scored cylinder and piston on this saw as well.i replaced cylinder and piston with used oem pro cylinder and piston with new caber rings.new pull rope.new sheetmtal plate on bar studs new chain catcher assembly.took saw apart cleand vac and press tested saw.notice the cylinder cover is orange not brick red and filter cover is brick red.reason being my personal 036 pro has a non pro top end so i switced it with mine.this saw has a non compensating carb and a non magnesium starter cover like as the pro saw does but does have adjustable oiler.i ported muffler have ran several tanks of fuel thru it.saw cuts oils and idles as should.400 ride included to lower 48
