028S oem parts help
BrokenAgain
OPE Member
7:28 AM
N idaho
New here. Picked up a used p28 super and going to go through it. Has 150 psi compression dry so a ok start. Question I have is with replacement av bushings. I've got the 028 IPL and it calls for 2x 1122 790 9905 and 1x 1121 790 9909. But I'm seeing eBay listing for others that supposedly fit like 1118 790 9920/9926, etc.. Chainsawr also has the latter listed for 028. What are the correct ones I should be looking for? I will post here for more help as I tear into this saw. Thank you for any help
Warped5
9:28 AM
Northwest IN
FWIW, this may help ..
Find a nearby Stihl dealer that manages their parts inventory with a product called PartSmart. If they do and are reasonably current on their software maintenance level, they can put in the part number and look to see if any other dealer has it in stock. Found many older parts that way back when I was employed.
Good luck!
Brad Button
7:28 AM
Angels Camp,Ca.
My IPL shows 1122 790 9905 for 2...1121 790 9909 for 1 and 1118 790 9930 for 1. I know on some of the Stihl saws there were several different numbers, one set was for soft AV bushings and the other numbers were for hard. Your Stihl dealer should be able to look up the numbers and go into their item notes that will tell them which is which.
