Thanks, I was thinking maybe the Mahle would be better with the thicker base, wouldn't be as thin after cutting, but wanted to make sure one didn't out perform the other.I don't think there's much difference between those two jugs.
Oh if your machining I'd go with the thicker base or check numbers on both?Thanks, I was thinking maybe the Mahle would be better with the thicker base, wouldn't be as thin after cutting, but wanted to make sure one didn't out perform the other.
Both are 44mmThey both 44mm?
I'm going to time them tomorrow. I noticed that they have different combustion chamber shapes and I was thinking that one may have better transfer tunnel shape giving it an edge over the other.Whichever has a lower exhaust port or thicker base. I'd time them.
Thanks!Top is a K$, if I am not mistaken. Look at the base. It’s a shiny alloy.
Timing about the same, but the Mahle is easier to machine and grind.
I kinda like the Mahle better.
Both great for builds.
Run it!I started cleaning up the transfer on the Male cylinder and it has some small grooves so I'll finish cleaning it up and use it to practice on.
It would probably be ok but the Stihl one is in great shape.Run it!
