Your favorite sealant to use on saws, and why
Mark71gtx
3:50 PM
Fuquay Varina, NC
I have seen several posts here and on other forums about different sealants used on chainsaws. It would seem that there are many different ones to choose from. I am interested to see what is your favorite, and why? What brand will you never use again, and why?
So far I have only used Permatex Motoseal. I have had good luck with it so far. I chose it because I can pick it up readily at virtually every auto parts store locally.
jmssaws
Banneded
2:50 PM
I've used derco for a long time,I've never had it fail and it smells great.
I rarely use it anymore,if I can at all I use a gasket.
Genius
First member of ASlite to receive a infraction
3:50 PM
Uncle Willys basement
I use Motoseal, it is readily available.
I do want to try Dirko when it comes time for a new tube.
jmssaws
Banneded
2:50 PM
I get Dirko from the stihl dealor for 13$ a tube,used it on mufflers and bases with out any problems. Good stuff but very stinky.
Steve
Excellence!
2:50 PM
I use motoseal and locate 518 depending on the situation. I like 518 for base gaskets because you don't have to rush to get the jug down like motoseal. Also if you use too much on a base gasket the uncured stuff hanging out in the transfers gets blown out the muffler. I like motoseal for clam shell engines and sealing impulse nipples.
Mag Craft
1:50 PM
Carpenter, Wyo.
Yamabond 4 because it is designed for sealing 2 cycle crank cases.
jake wells
no longer here
2:50 PM
ky
i use loctite 518. i also use permatex no# 1 or 2 gasket maker.
3:50 PM
Is Permatex 51817 Anaerobic Gasket Maker basically the same stuff?
d.l.d
2:50 PM
Arkansas
1194/1184 because it hasn't let me down yet and i haven't found anything i like better.
Carbine
3:50 PM
Ohio
I've used permatex copper with good results (I've seen some pretty reputable guys on another site use it), but recently picked up some loctite 518 from all the talk.
mdavlee
Hillbilly grinder
3:50 PM
TN
I used that spray on paper gaskets if I was making one. Lay it out and spray it and let it dry good on both sides then spray lightly again and assemble.
P.M.P.
Stiff Member
3:50 PM
Michigan
I have some Hondabond 4 like it bcause that's what on hand.
