t4driller
Daddy Day Care
- 8:55 PM
- Feb 23, 2016
- Southwest pa
Looks like it will be as good ad it left the factory now.. well done sir.
Making progress .....
This one cleaned up
This one needed additional help:View attachment 87408 View attachment 87413 View attachment 87414 View attachment 87415
Thanks men !Where's all the shavings [emoji33]lol
Looks nice [emoji106]
That's actually better than factory.Looks like it will be as good ad it left the factory now.. well done sir.
He's likely using an impact. I use one all the time, to DISASSEMBLE/LOOSEN bolts. Took me about 2 saws to figure out using it for assembly was a no-no. The work repairing threads wasn't worth the increased assembly speed. But that factors in giving-a-shít and actually doing the repairs.Wonder what he uses.. I have a little battery drill i use and it doesn't have the power to strip out anything.
Impact and magnesium/ aluminum don't mix to well. Guess his give a *f-word is broken.He's likely using an impact. I use one all the time, to DISASSEMBLE/LOOSEN bolts. Took me about 2 saws to figure out using it for assembly was a no-no. The work repairing threads wasn't worth the increased assembly speed. But that factors in giving-a-shít and actually doing the repairs.
Thanks men !
All of the shavings are getting saved so I can dump them into the case just before i bolt it down for the last time
+1I use one both for assembly, and disassembly. I just don't use it to tighten the bolts. I snug them up, and then tighten with a tee handle.
As you said, it's a matter of give a damn.
