Yamabond or Loctite
rattler
5:45 PM
NC
It,s about time to order more sealer and I can't make my mind up which to order I am a fan of yamabond but their is so much waste. What you guy,s useing ?
rattler
5:45 PM
NC
Been using Yamabond since I started this saw fixing thing. Which ain't been that long.
And the Yamaha dealers close.
Same here and I like but I wast a bunch in each tube.
rattler
5:45 PM
NC
I will go check tommorow Randy Thank you.
Sty57
4:45 PM
Land of Cheese & Beer
jake wells
no longer here
4:45 PM
ky
i use versachem no# 1 or 2 gasket maker it is cheap, gas/oil resistant and dries rock hard.
CR500
5:45 PM
Western NY
I use this....
But that Motoseal is a good product too. Hell I even have Dirko.
I use different sealers on different engines depending on how the transfers enter.
The 518 can be persnickity.....
How about for a base gasket dressing? I know it works good for case gaskets
5:45 PM
Care to elaborate??? I used it on several saws inlcuding 044#1 (used dirko on the clamshell). 044#1 usually runs just great, but when it gets hot sometimes the idle pics up. I was thinking it must be the clutch side seal (which I replaced), but now you are making me wonder if it could be the base gasket.
Any thoughts or educated guesses???
