They all have that some just show up more extreme than others even my 064 show's color mid way down the rod.Was the rod blued like that when you put it together? I’d be checking that big end bearing very closely...
I like 20 or so in a 66. Mine has 17.I like that intake, and I think your #s are good. Not sure if I would move the upper or not, 25* of blow down is just fine.
The blue on the rod is about heat. A couple of reasons why..I've seen that twice before...
His saw seemed to run pretty good as it was though.
Well as I see it you port timing is pretty good it's ok to have spit back it's more less normal for a chainsaw. And yep I'm sure the argument will begin after my comment.lolHow would I reduce the spit back? I would like to keep that oil in case as much as possible.
I'm watching … we don't know if we don't try!!!
