- 12:48 PM
- Apr 28, 2016
- Croatia
That makes sense.I think the go the 661cm to 660 route is that's what they can get there hands on here in the states.
I modded the air filter cover on the bottom to let chips out. Now I use the max flow filter and have modded the MF cover on the bottom to let chips out.
What is the verdict on these door stops when they get converted to non-CM?
Do they stop misbehaving?
Is the power output similar or better than on a CM unit?
@jmester had one and gave up on her.
I don't know what issues his had, maybe he'll chime in.
Considering the premium Stihl charges, whatever issue the 661CM has should have been fixed a long time ago!
As for mine, one word AWESOME! I think it runs better since it switched it to non-mtronic!
Is the swap as simple as it sounds? Any modifications needed to fit the 660 flywheel and carb?
I've had a few ......... still have 2 since brand new
Most issues I've seen are the harnesses need soldered at every connection. My oscilloscope showed me the intermittent issue a few years back on someone elses saw. Didn't upgrade anything and that saw is still cutting today, that one has the original intake too.
Max flow is a MUST ............ so too is a muffler mod.
- They run even with any 394/395, each one, ported against ported or not ported at all
I think all the modern AT/MT saws have had a period where bugs have been ironed out, upgraded parts etc. It appears those who choose to understand the tech are the ones with the most reliable saws...lol.
Do u have any videos or pictures on how u modded the cover?
check this post out - http://opeforum.com/threads/show-me-your-air-box-mods.8063/page-2#post-722578
here are some more... see attached files
Nice mod. I remove the rubber flap on air filter cover and take out the slide up top for summer use. Can put it back for the winter if needed, clips in and out. I think it seems to help as well.check this post out - http://opeforum.com/threads/show-me-your-air-box-mods.8063/page-2#post-722578
Nice mod. I remove the rubber flap on air filter cover and take out the slide up top for summer use. Can put it back for the winter if needed, clips in and out. I think it seems to help as well. View attachment 140069 View attachment 140071
The black rubber flap part seals against the cylinder head cover and directs the hot air in. Without it there, it doesn’t get directed into the saw intake. Less chips on the filter without it there (they come off the cylinder then directed around intake flange ). I can always put it back if I notice ill effects, but I haven’t yet on 461/661. The max flo removes that rubber flap, so in theory it too would be directing in hot air according to your theory.by removing the black slide from the top you are drawing in hot air into the air filter from the engine. Per Scottie too Hottie you wouldn't even do this in the winter. Because the saw runs better on cold air. The only time you'd only want to remove that slide would be if you were having carb icing.
Have you tested that? The black rubber flap part seals against the cylinder head cover and directs the hot air in. Without it there, it doesn’t get directed into the saw intake. Less chips on the filter without it there (they come off the cylinder then directed around intake flange ). I can always put it back if I notice ill effects, but I haven’t yet on 461/661. The max flo removes that rubber flap, so in theory it too would be directing in hot air according to your theory.
I was eyeing that spit back thing, it did look sort of restrictive. I bet remove that, a mm and max flo make a big difference alone?I was adding to my above post as you posted this. Again taking the black flap is a great idea for exactly the reasons you stated.
That is the slide's purpose(to draw in hot air from the engine).(see attached pic from manual).
Yes that is a problem with the max flow IMO. However I have tested the max flow with MF cover on vs just the HD2 and it was still faster a decent margin.
Another issue with the HD2 is that you must leave the spit back cap in place or the spit back will soak and hurt performance of HD2 quite a bit. You can take the spit back cap out (less air restriction) with the max flow.
