- 9:54 PM
- Dec 31, 2015
- East Jordan, MI
I drilled the main in that 390 you raced against in MO, Levi was running it in the 6 cube against your 395. I believe I went 2 sizes bigger. Got it down to 1 turn out. Next time I'll try going your route, and maybe only going 1 size biggerIf you are 3 turns out you probably need to lower the pop off pressure or raise the metering arm (which will lower the pop off about 1-2psi) to open the needle further.
