What's on your bench?
RI Chevy
6:43 AM
earth
Yup. Make them earn their keep.
460 magnum
5:43 AM
Very southern Illinois
Maybe but I like it. I might just copy it.
Well it worked it could use some more modifying but worked pretty good for my first attempt at build one of these 20180521_221954.jpg
Maybe if it was built out of a different kind of steel or something. The fingers would try to bend if I put to much pressure on them.
6:43 AM
Well it worked it could use some more modifying but worked pretty good for my first attempt at build one of these View attachment 125780
Did you try it using a small impact driver? The added chatter might be enough to free up a little bit
6:43 AM
23812E38-1BE7-476A-B75F-7219ECCA6429.jpeg 1EA80C66-F5E0-4C3E-9314-AC9543FE1371.jpegThat’s a wj71 from a 394xp in there. Borrowed a top plate from a rwj xtorq carb to convert it to top impulse. Took some work but it all fits. It’s a beat up work saw with a am topend. I did some modding to it. We’ll see how it runs with this setup vs stock carb.
6:43 AM
6:43 AM
Did you try the rwj?
Yeah, on a ported 385 and a 395 one time, it ran ok but more fussy to tune than the stock carb. Didn’t notice a whole lot of difference but I didn’t time the cuts between the two. Im guessing the 394 carb should supply the most fuel.
6:43 AM
I’m not at the level of some of you guys just experimenting for sure
6:43 AM
I guess I haven't seen as much improvement using them on a stock saw. They do seem to help once ported.
It is a little weird having the H screw out 2.5 - 3 turns.
6:43 AM
I bet on a ported 372 they make a good difference
6:43 AM
Anyone have a husky case splitter or another tool I can use to split a dolmar case? Im hoping to not have to buy one.
ETA: I HAVE ONE ON THE WAY
You just need heat. A puller is convienient, but heating a case up t0 325/350 after removing the pins and bolts is really all you need. Then wack the crank with a piece of wood/brass/nylon hammer and the case will literally fall apart.
Then a 2 jaw or bearing puller will remove the bearings from the crank.
srcarr52
6:43 AM
Iowa City
If you are 3 turns out you probably need to lower the pop off pressure or raise the metering arm (which will lower the pop off about 1-2psi) to open the needle further.
mettee
3:43 AM
Arizona
I don't want to chance damage and I have never split a case like that. But I got splitter on the way so I'm good either way.
Moparmyway
Its just a saw
6:43 AM
In a meeting
When I thin shafts on a carb I use red on the shutter screw. That’s the only one.
Only 1 or 2 threads left normally
That is one place where I probably would also use the stronger stuff .............. but only if its thinned like you're doing
Honda chainsaw. Needed a new connecting rod, governor gear and adjusted. Ugly outside, clean inside.View attachment 125809
That MUST be one heavy chainsaw, cast iron flywheel and all ......... valves for a 4 stroke, you sure that aint for something other than a chainsaw ?
