usmcbuckwild
Buck
- 11:45 PM
- Dec 24, 2017
- NW CT
What are the other codes? Like P06xx?
If so, those are typically ECM death codes.
You didnt happen to remove any ground wires or the like while you were in there, did you?
This is what I was going to say. Joe, check and make sure the grounds are clean and have good connection in the harness. Verify the alternator voltage regulator is outputting within spec, low voltage spikes will cause those codes as well.
