usmcbuckwild
Buck
- 5:55 PM
- Dec 24, 2017
- NW CT
50:1 with limiter caps?
Yup
Left a ridge around the outer edge of the band?
Exactly!50:1 with limiter caps?
I have seen a bunch of 461 like that, extremely worn on the intake skirt, I thought they were sucking dirt!I don’t think an almost brand new 461 piston is supposed to look like this....
Looks like exhaust side in his picture if I’m not mistakenI have seen a bunch of 461 like that, extremely worn on the intake skirt, I thought they were sucking dirt!
No worries, the weird thing is it seems like a lot of them do that right off the bat and then look the same way after many hours of run time! Not sure if it’s dirt or what?EDIT: yup intake side, sorry guys.
It makes you wonder what the cause is, oil, warm up prosess, clearance issues or fines! Or what?Yes, intake side. Had me concered. I made sure to beverl the intake port and radius the bottom of the skirt a little to keep it from catching anything.
Just a question to brew over for you guys, when’s the last time you saw a tree service guy tune a saw? Go as far to delete limiters? Some run crappy gas mix with 50:1... most of the time there chains aren’t the best either and the saws abused... add all these things up and it makes it hard to really determine if it’s a flaw with the product or just abuse.
I noticed loggers take better care of there saws usually. We cut a lot more wood so it makes sense.From what I have found, most tree guys either continue to use a crappy running saw or just toss it to the side and grab another. The others attempt to adjust and screw it up royally.
I remember working with a logging company years ago the main cutters would make minor adjustments throughout the day to compensate for wide temperature swings (30-40 in the AM reaching 70s by mid day). I was actually talking about this with my neighbor’s FIL (who is visiting for the birth of the neighbor’s baby next week). He worked for logging companies in Oregon/Washington/Alaska and said they would have to make tune adjustments as they went further up the mountain for elevation. Start out in the valley and work their way up to the peak. I’ve never been in the mountains out there but I can see how that is feasible.
Yea the only time they good gas and carburetors tuned is when they bring them in to get parts replaced there hard on chains big time I don't sharpin chains for them anymore they can figure out how to do that crap themselves.Just a question to brew over for you guys, when’s the last time you saw a tree service guy tune a saw? Go as far to delete limiters? Some run crappy gas mix with 50:1... most of the time there chains aren’t the best either and the saws abused... add all these things up and it makes it hard to determine if it’s a flaw with the product or just abuse.
Yep I'm in WA and it's common sense to bring your tools you can tune your carb at home but you'll be doing it again when you get up at the landing sight. LolFrom what I have found, most tree guys either continue to use a crappy running saw or just toss it to the side and grab another. The others attempt to adjust and screw it up royally.
