What's everyone's preferred method of gasket removal
decableguy2000
12:49 AM
WNC
I'm in the process of rebuilding a 346xp, and need to remove the remanding gasket material. I have always used a razor blade and small wire brush. But I'm always scared I'm going to gouge the magnesium. What are your preferred methods?
Coutu
12:49 AM
Mass
Razor blade then brass wire wheel on an electric impact just a bit. If you use a wire wheel make sure it spins in the opposite direction of the way the bristles are leaning. So basically if you have a well used wheel that has spun clockwise all it's life, don't spin it counter-clockwise; it'll be too aggressive.
cus_deluxe
terms of service violator
12:49 AM
Michigan
I use a real flexy putty knife.
J_M____
12:49 AM
CT
Roloc disc with the very soft/fine scotchbrite(grey I think) seems to work quick and easy
Moparmyway
Its just a saw
12:49 AM
In a meeting
I stick with a razor blade
If theres any spot on the case or cylinder thats being stubborn, I’ll hit it with acetone and get a new razor on it. Razors are cheap, I’ll happily go through 2 or 3 single edge razors on each saw
beaglebriar
The Peanut Gallery
12:49 AM
Warren Center, PA
I do the same. A little carefully placed paint stripper also works great on stubborn gaskets.
Disciple of Monkey's
11:49 PM
Been using a blade from a ceiling tile/box cutter knife. When the angle of the dangle is right, it goes pretty good. Open to new ideas, as always trying to improve.
srcarr52
12:49 AM
Iowa City
Super scraper.
Onan18
OPE Sponsor
12:49 AM
Georgia
AvE fan Steve?
isaaccarlson
11:49 PM
Colfax, WI
Scratching the surface is ok as long as it’s not a gouge. The sealer will take care of it. I always use sealer.
heimannm
11:49 PM
Dike, Iowa
I still have most of the can of this stuff. Really works well, no doubt that is why it is no longer available.
Mark
