Willoughby
Im installing a aftermarket 52mm kit, and would like to also do base gasket delete , what sealant should I use ?
Switch to red, better stuff.I have been using Permatex ultra grey lately, no problems.
518 sets in the absence of air, so exposed 518 that gets squeezed out into the crankcase just washes away when the saw is ran. This way you never really have the risk of excess sticking out into the lower transfers or impulse circuit on some saws. Although, I’ve never had a problem with other sealants as long as you use a thin but consistent layer. Too much will just get squeezed out excessively. I do prefer the dirko ht or 1184 3 bond I use now over 518 for several reasons. It comes down to personal preference really. There’s plenty of choices to choose from. Experiment and choose the one that works best for you.I'm using it but what makes 518 better than the Yamabond sitting next to it in the box and how does it aid in a smooth transition? I appreciate that it doesn't set and can be cleaned up later. Less pressure to get it perfect the first time.
