Nutball
- 4:01 AM
- Oct 31, 2018
- Mt. Juliet, TN
So, my 490 started out likely as a home depot return I got from a refurbisher for cheap. It looked nearly new, linear marks in the cylinder were few and couldn't be felt: they were just polished lines. After a port job and a thorough cleaning to ensure metal dust is removed, and 9 15" cookies later I take it apart since I used the wrong gasket maker and noticed the stuff liquefying. The saw ran very well the whole time. After I took it a part I notice many scratches in the cylinder that I can feel with my finger nail. WTH? Assembled with plenty of Benol... lots of it to avoid extreme initial wear from any left over metal dust. 40:1 fuel used.
The scoring seems pretty even around the cylinder, so the ring ends or ports don't seem to be the problem.
Guess I'll run it on 32:1 for the rest of it's life. I don't think new rings would be worth it would it?
EDIT: I just remembered when cutting cookies, on the 4rth or 5th in a row it seemed to loose a little power as if it was an old wore out saw getting hot. It didn't loose much though, and the cut times were only getting faster.
