YesI got the low profile file dont I! ?
I need the 13/64 right? *bangs head off wall*
Here is two out of the 3 that I have. And the blue one was $15 cheaper.
I did say looks like 4mm 3/8 lo pro, I could see from the 2nd tooth and the file marks..
We all make mistakes, and we all laugh at how silly we've been
But the best bit, is we learn from it,
If you plan on using a guide, you will need the appropriate guide for file size so it holds the correct percentage of the file above the tooth. I personally prefer the husqvarna roller guide as a cheap effective guide which can be picked up at your local tractor supply with the jonsered name. If you'd rather stick to the stihl style guide, I should have one I could send you that I'll never use again. The husqy guide is just that much better. Where about in Ohio are you?
The Stihl one I got is the 5.2mm, 13/64 oneI’m going to buy the blue one. I see there is a 7/32 and a 13/64. Which one?
