blsnelling
Friend of the Riff Raff
- 7:16 AM
- Jan 8, 2016
- Franklin, OH
If I'm reading right, that only goes up to .020". His squish is greater than that on two corners.
Its just another way to skin the cat.Well that wouldn't do you a whole lot of good .You flatten that stuff out and use the chart on the folder to get the measurements not peel off and use a set of micrometers like solder .
Never thought of that but even with 20 thou gasket thickness for Stihl it would not be enough for many .Seems to me like the 038 mag was around 46 thou stock .The 200T was around 35 I think . I took them both to around 23 if I recall .The two 038's and the 200 are the only ones I've cut down .Nothing on the Husqvarnas and nothing you can do to the McCullochs regarding that .Pull the gasket and measure with the yellow, then just add the gasket thickness for total squish
Al, the yellow plastigauge isnt a cure for everyone or everything.Never thought of that but even with 20 thou gasket thickness for Stihl it would not be enough for many .Seems to me like the 038 mag was around 46 thou stock .The 200T was around 35 I think . I took them both to around 23 if I recall .The two 038's and the 200 are the only ones I've cut down .Nothing on the Husqvarnas and nothing you can do to the McCullochs regarding that .
Correct. If it does read above .020" then solder will read about the same. .023" solder wouk d read .018-020". Plastigauge was reading .011-012". 372 run like that for a tank or two before I pulled it apart to change something. Then I checked it again with plastigauge and figured that out.Well that wouldn't do you a whole lot of good .You flatten that stuff out and use the chart on the folder to get the measurements not peel off and use a set of micrometers like solder .
Not true. Maybe most models you’ve worked on.Most Stihl cylinder gaskets are .017".
