Toad22t
- 2:51 PM
- Jan 4, 2016
- Central Wisconsin
That's going to be a big head! What saw is this for?
You going to make a roller for the carb or fab up some linkage, for the throttle arm?View attachment 83921 Here's your pic @Stump Shot
Linkage. Just a straight piece will work I believeYou going to make a roller for the carb or fab up some linkage, for the throttle arm?
This was a 288. Has a 181 cylinder and piston181 actually had a linkage. 281/288 had the roller on the carb.
It didn't happen lol my badWhere is the morning piss rev vidja?
Oh well hopefully it fires up with noodles problems tonight.It didn't happen lol my bad
I let you downOh well hopefully it fires up with noodles problems tonight.
Nope not at all buddy.I let you down
Use red loctite on the high screw. Thread it on a few turns before applying the red or it'll migrate into the jet passage. Turn the screw a little bit just before it cures so it'll stay stiff without locking.The spring was a failure but I robbed 2 off of junk carbs and stacked them to fit.
The 2 springs works just fine but thank you for the tipUse red loctite on the high screw. Thread it on a few turns before applying the red or it'll migrate into the jet passage. Turn the screw a little bit just before it cures so it'll stay stiff without locking.
Yes sir. Back to dead ignition the nowLooking good Dave. I bet it wouldn't be terribly difficult to rig up a primer bulb on it. Would be handier than a squirt bottle...??
That stinks.Yes sir. Back to dead ignition the now
@Stump Shot should be able to help this situation out.Yes sir. Back to dead ignition the now
You hopefully lol.Who? Lol
