- 3:56 AM
- Dec 30, 2015
- Brewster, NY
I hate evergreen sap!!! Very tough to remove.
Use some mix out of your gas can, easy peasyI hate evergreen sap!!! Very tough to remove.
BUT...... That's not Ecofriendly! [emoji1787]
Using the mix to clean the saw.Use some mix out of your gas can, easy peasy
Hell of a pitch cutter, works in a pinch if I’m out of keroseneUsing the mix to clean the saw.
I heard that from a guy out on the west coast. Or wherever he is from on God's green earth.
I spoke to a friend who is a Stihl dealer today and knows saws and modified saws. He builds them.
I asked about the added functionality of the computer tuning and he said its no different to doing it on the saw.
You make a mod then re-calibrate, and the saw sets its fuel curves to match the new airflow characteristics of the mods.
He said he has just redone his Gold certification for the 3rd time and they made no mention of separate adjustable limits when using the software.
I call bogus
- Kalibrierung durch den Kunden entspricht einer Vergaser Standardeinstellung mit verklipsten Begrenzerkappen. Die Grenzen sind fix und können nicht verschoben werden.
- Kalibrieren mit SDS entspricht der Grundeinstellung mit vormontierten Kappen. Die Regelgrenzen werden verschoben.
Thats on Mtronic Saws till Version 2.0, these saws do only a factory reset with the 90 seconds run on triangle position.
Since Mtronic 2.1 and its real calibration process only for the WOT part.
I have some german document here which say the idle tune will only be affected with the Software calibration routine.
Thought all you Stihl Bros could speak German?well hell I can't read it
I haven't had any idle issues with the 462's
Thems hyroglyphics Mike.stihl이 느리다.
what is?
Fugging with no rubbers.
