Ed Heard (EHP) recently bought a new MS462 and logging with it. He says he won't port it until he feels the rings are maximum fully seated. This gives him a comparison to his other stock saws.
He's making daily reports on it and after its first day he claimed the 462 had no more power then his well broke in stock 361/362s.
Compare them stock and you will see the difference. But all the new technology and R+D is about reaching the EPA Requirements
That’s interesting, do you know what size bar he’s running?
Jason Egan did some logging with a stock one before porting and felt it would be real close to a 461.
That’s kind of disappointing, both 70 class saws. The 462 the latest and greatest technology but slower. This video definitely changed my thinking about the 462. I know Scott’s not done with the 462 yet, but how much gain can be left in it, probably not much.
1 second in a 35 second cut means very little in real word cutting.
saw is lighter, better av system, clean air system, better fuel mileage, less hydrocarbons in your face, easy to work on.
Here's my rhetorical question for Scott... the new 462 does a great job of achieving EPA mandates of minimizing emissions by chasing out spent exhaust gasses with fresh air instead of fresh charge. But the engine power is still a factor of supplying air and fuel. So what can we guess attributes the better performance of the older saw to?
Your experience:
a) more familiarity with the older design, while you're still learning where to make gains on the new saw?
Your port work / settings:
b) you can manually tune the carb closer to the edge than the m-tronic can?
c) more aggressive porting numbers, or higher static compression on the 440?
d) the 462 just isn't broken in yet?
The inherent design of the 462:
e) better timing numbers achievable on the 440 jug compared to what you can do on the 462 cylinder?
f) larger intake/larger carb/carb jets to supply more air/fuel on the old style saw?
g) cooling the cylinder from using fresh charge to chase out exhaust gasses instead of clean air to make it run cooler/better?
Again, great job to you, and also great job to Stihl engineers. I think we all get wrapped up in power gains sometimes, and it's important to remember, if you were to continue cutting the same number of 4 by 4 posts over and over again, the 440 might be a second faster through 12 beams, but I bet you'd cut more with the 462 on a tank of gas before it runs dry, than you would with 440. And if you keep cutting indoors, Scott, the noxious gasses should be reduced too. ;-)
Ed says some of the bigger hardwood he's logging is in 36"-42" dbh so he has to be running at least a 25" b/c.That’s interesting, do you know what size bar he’s running?
He also had a 562 cutting with a stock 395 in 28" wood. Ed sure is good with chain and he sure knows how to run saws to get the most out of them. A stock 362 is not going to run with a 462 in anything other than foam wood IMHO.Ed Heard (EHP) recently bought a new MS462 and logging with it. He says he won't port it until he feels the rings are maximum fully seated. This gives him a comparison to his other stock saws.
Let’s see if I can get this quote from Facebook to work.
This was after a week of solid use 3 to 4 gallons...
“Can’t believe I’m gonna say this, but from my LIMITED experience, 462 will do anything you need with a 28” bar! Not sure if I’ll need a 500? Lol!!”
Yep he said his 562 will eat his new stock 462 but I teased him by saying his porting tools will fix the 462.He also had a 562 cutting with a stock 395 in 28" wood. Ed sure is good with chain and he sure knows how to run saws to get the most out of them. A stock 362 is not going to run with a 462 in anything other than foam wood IMHO.
Sent from my LG-H871 using Tapatalk
Yes same here. My posts should have gone somewhere else.P.S. Apologies to Scott for discussing other people’s saws in his thread. Comments should have been reserved for a more general 462 thread...
Where is Ed talking about this? Or is it a private conversation between you 2Yep he said his 562 will eat his new stock 462 but I teased him by saying his porting tools will fix the 462.
He says his stock 362's got over 50 tanks through them so makes sense they'd keep up with a out of the box 462.
If it was just between me and Ed I would never share it, Lol.Where is Ed talking about this? Or is it a private conversation between you 2
Is there a thread on there where you guys are talking about itIf it was just between me and Ed I would never share it, Lol.
We're both regular members over at Chainsaws Forestry Forum.
You can catch up on the latest over there.
