retro
Void where inhibited
So explain the vacuum pulse that actuates the fuel pump diaphragm in the carb. I’m not trying to be combative on this either but I definitely do not see things the way you do
There is a vent to atmospheric pressure on one side of those diaphragms that forces them to move. Now, if you were to plug that vent you'd have a true pump... one where forces other than an existing natural force must be exerted on BOTH sides of the diaphragm (push/pull) to cause any movement. Since it is external pressure, not vacuum that causes movement of a diaphragm, you can increase the ability of that device to perform work by simply increasing its surface area, without increasing negative pressure signal strength.
Ok, I'll go away and leave y'all be now... time to check into another Holiday Inn for brain calories replenishment.
